3 Replies Latest reply: Nov 8, 2013 10:24 AM by gasparuben RSS
volume-clone-create not working
gasparuben
Currently Being Moderated
Using ZEDI I have generated following code to generate a clone on C-mode cluster:
require 5.6.1;
use lib '/opt/netapp-manageability-sdk-5.0R1/lib/perl/NetApp';
use strict;
use warnings;
use NaServer;
use NaElement;
my $s = new NaServer('Cname', 1 , 15);
$s->set_server_type('FILER');
$s->set_transport_type('HTTPS');
$s->set_port(443);
$s->set_style('LOGIN');
$s->set_admin_user('vsadmin', 'XXXXXX');
my $api = new NaElement('volume-clone-create');
$api->child_add_string('junction-active','true');
$api->child_add_string('junction-path','/ORA/dbs03/PEPE');
$api->child_add_string('parent-snapshot','snapscript_31102013_195117_92');
$api->child_add_string('parent-volume','postgres03');
#$api->child_add_string('space-reserve','true');
#$api->child_add_string('use-snaprestore-license','<use-snaprestore-license>');
$api->child_add_string('volume','pepe');
my $xo = $s->invoke_elem($api);
if ($xo->results_status() eq 'failed') {
    print 'Error:\n';
    print $xo->sprintf();
    exit 1;
print 'Received:\n';
This is failing with error:
$ perl /tmp/clone.pl
Error:\n<results reason="Aggregate aggr4_c01n02 does not exist" status="failed" errno="14420"></results>
aggr4_c01n02 is the containing aggregate of the parent volume. It definitely exists. The filer is running Ontap 8.2P3. I am connecting  to the cluster using a lif.
Thanks for your support.
Ruben
  • Re: volume-clone-create not working
    gasparuben
    Hi,
    Just to say I have tried with the latest version of Zapi and still it fails with same error:
    [oracle@dbsrvg407 bin]$ perl /tmp/clone.pl
    The aggregate does exist.
    c02::> aggr show
    Aggregate     Size Available Used% State   #Vols  Nodes            RAID Status
    aggr4_c01n02
               130.7TB   85.25TB   35% online      12 dbnasb402        raid_dp,
        normal
    Thanks for your time,
    Ruben
More Like This
  • Retrieving data ...
