4 Replies Latest reply: Sep 18, 2013 11:13 PM by MIELETON- RSS
No clusters visible in Unified Manager 6.0RC1
MIELETON-
Currently Being Moderated
I've installed OCUM 6.0RC1 according to instructions and I'm able to add clusters, but even after waiting for couple of hours there's nothing displayed on the dashboard except "Cluster add operation might take a few minutes. The event “Cluster Add Failed” is raised in case of failure." There's nothing visible on the Storage -> Clusters list either, but if I try to add one of the clusters again, I get an error saying the cluster already exists.
I've tried deleting the OCUM virtual machine and deploying it again and rebooting the virtual machine after waiting for some time with no luck. Network settings are correct and firewall rules allow HTTPS access to cluster management lif from the virtual machine.
Is there any solution to this or is this a known error that will be fixed in GA?
Thanks,
Jussi
More Like This
  • Retrieving data ...
