9 Replies Latest reply: Jan 30, 2013 10:40 AM by JGPSHNTAP RSS
Automating Disk and shelf firmware Updating
JGPSHNTAP
Currently Being Moderated
Hey all -
So, I have some questions regarding start-nadiskupdate and start-nashelfupdate.
I've written a simple script to copy the firmware files from our http server over to each filer...
cls
$file = read-host "enter File list"
$ftype = read-host "enter file you want to copy"
$Hosts = gc $file
$Hosts | % {
$filer = $_
Write-Host "Copying $ftype to filer" $_
copy-item -path "\\httpserver\c$\home\http\firmware\$ftype" -destination "\\$filer\etc$\software" -force
I've also done it this way as well -
$warningpreference = "SilentlyContinue"
#### Reset registry key
## Set credentials
$pwd = Read-Host "enter password"
cls
$password = ConvertTo-SecureString $pwd -AsPlainText -Force
$cred = New-Object -TypeName System.Management.Automation.PSCredential -ArgumentList "northamerica\jgoldfar",$password
$Hosts = gc $file
$Hosts | % {
#Write-Host Connecting to controller: $_
$c = connect-nacontroller $_ -https -cred $cred
Write-Host "Copying All.zip to filer" $_
Invoke-NaSsh -command "software get http://httpserver/firmware/all.zip -f"
I prefer option 1.
So, let's say we get the firmware files to the software directory.   Now I wanted to play around with get-nadiskupdate and get-nashelfupdate.
I was surprised to know that these cmdlets don't actually do some sort of software install all.zip or all_shelf_fw.zip.   So, when I ran get-nadisk | start-nadiskupdate - I saw in the messages file that all disks are updated.  Obviously, it didn't do a software extract.
Am I now forced to go back to connecting via https and issuing the commands via ssh?   I didn't find a powershell cmdlet that will do software install.
Also - as per the man page on start-nadiskupdate - I tried this.
PS C:\powershell> start-nadiskupdate
start-nadiskupdate : Value cannot be null.
Parameter name: value
At line:1 char:1
+ start-nadiskupdate
    + CategoryInfo          : InvalidOperation: (uswsns015a:NaController) [Start-NaDiskUpdate], ArgumentNullException
    + FullyQualifiedErrorId : ApiException,DataONTAP.PowerShell.SDK.Cmdlets.Disk.StartNaDiskUpdate
I'm using version 2.1.
Thanks all in advance.
  • Re: Automating Disk and shelf firmware Updating
    vinith
    Hi Goldyfarbs,
    Could you please emulate the scenario by using the PS toolkit v 2.2 ? i guess you are using version 2.1
    also Can you try Invoke-NaSsh cmdlet, it sends a Data ONTAP CLI command via SSH.
    Invoke-NaSsh -Name <ControllerName> -Credential root "ndmpd status"
    Invoke-NaSsh -Name <ControllerName> -Credential root "ndmp probe"
    Here are some more details regarding this cmdlet.
    Invoke-NaSsh -Command <String[]> [-Credential <PSCredential>] [-Port <Int32>] [-Timeout <Int32>] [-WhatIf]
    [-Confirm] [<CommonParameters>]
    PARAMETERS
        -Command <String[]>
            The command string to send to Data ONTAP.  If the command string contains hyphens, enclose the command in
            quotes lest PowerShell attempt to interpret those as cmdlet arguments.
            Use this argument to explicitly provide SSH credentials for authenticating with Data ONTAP.  If credentials
            are provided, they take precedence over any other credentials that may be available.  If not provided, the
            cmdlet will look for valid credentials from either the specified NaController object or
            $global:CurrentNaController as appropriate.  Failing that, credentials will be sought in the Toolkit's
            credential cache.
        -Port <Int32>
            The port on which to connect to the storage controller.
        -Timeout <Int32>
            Connection timeout in milliseconds.
        -WhatIf
        -Confirm
        -Name <String>
            The name or address of the controller to connect to.  If a hostname is specified, it must be resolvable to an
            IP address.  Specify either this argument or the -Controller argument, but not both.
        -Controller <NaController>
            The controller to connect to, embodied in an NaController object as returned by Connect-NaController.  Specify
            either this argument or the -Name argument, but not both.
      JGPSHNTAP
      Vinith -
      I'm very familiar with invoke-nassh.  I try to avoid using that b/c I would rather use the standard cmdlet's from powershell but I didn't find anything that suited software install.   So, in my opinion, start-nadiskupdate is not very useful b/c if you have the proper options on, once you do a software install the disks automagically start to upgrade.
      As for shelf firmware upgrade, you would have to initiate a software install all_shelf_fw.zip and then do a storage download shelf from a controller.  I can initiate a invoke-nassh -command "software install all_shelf_fw.zip" and then do start-nashelfupdate.
      I am currently using ontap toolkit 2.1 with PS 3.0
      I can upgrade to 2.2
        JGPSHNTAP
        Vinith -
        v2.2 doesn't have any affect -
        At line:1 char:1
        PS C:\powershell> get-natoolkitversion
        Major  Minor  Build  Revision
        2      2      0      84
          JGPSHNTAP
          Also - I'm seeing this as well -
          PS C:\powershell> invoke-nassh -command "software install all_shelf_fw.zip"
          software: installing software, this could take a few minutes...
          software: installation of all_shelf_fw.zip completed.
          sw_find_kernel: exec_status=1
          WARNING: software: installation of all_shelf_fw.zip was not successful.
          If I check the messages log, I see the following
          Tue Jan 29 10:18:12 EST [filerb:cmds.software.installDone:info]: Software: Installation of all_shelf_fw.zip was completed.
          Tue Jan 29 10:18:12 EST filerb:cmds.software.installNotDone:info]: Software: Installation of all_shelf_fw.zip failed.
          So has it completed or has it not completed.  ??  Wierd..
            bsti@plex.com
            Goldyfarbs,
              Have you ever been able to install a shelf firmware update using a zip file?  I've never tried it, and don't think it works.  What I've always done, and is per the installation instructions, is to unzip the file first then copy the firmware files (.sfw and .fvf) to the /etc/shelf_fw directory.  Then you can issue the storage download shelf command (or Start-NaShelfUpdate cmdlet).
            Perhaps you can edit your PoSH process where you manually unzip the firmware files to a directory first, then perform a copy with PoSH and then issue the update command.
    JGPSHNTAP
    B -
    Can you try doing an invoke-nassh -command "software install all_shelf_fw.zip" and see if you're seeing the same results we are seeing.
More Like This
  • Retrieving data ...
