This Question is Answered (go to answer)
2 "helpful" answers available (5 pts)
16,061 Views 1 Replies Last post: Sep 20, 2008 9:52 AM by Daniel Prakash RSS
mitchellcipriano Master 71 posts since
Mar 17, 2008
Currently Being Moderated
Sep 19, 2008 2:22 PM
Vfiler and Main Filer System Info
Hi,
I have created vfiler on the simulator and trying get the system info data  for  main filer and vfiler create using Manage Ontap Api. I am getting the following response
Main Filer system info:
<system-info>
        <system-name>netapp01</system-name>
        <system-id>0099909261</system-id>
        <system-model>Simulator</system-model>
        <system-machine-type>Simulator</system-machine-type>
        <vendor-id>NetApp</vendor-id>
       <system-serial-number>987654-32-0</system-serial-number>
        <partner-system-id>0099912783</partner-system-id>
        <partner-system-name>netapp02</partner-system-name>
        <board-speed>0</board-speed>
        <board-type>Simulator</board-type>
        <number-of-processors>1</number-of-processors>
        <memory-size>512</memory-size>
        <supports-raid-array>false</supports-raid-array>
    </system-info>
Vfiler System info:
<system-info>
        <system-name>vfiler1</system-name>
        <partner-system-name>vfiler1</partner-system-name>
    </system-info>
</results>
Both system name and serial number comes as same from the simulator. But in real time , I think system id will be different for the main filer and v-filer.  Can you please confirm.
Daniel Prakash NetApp Employee Guru 461 posts since
Mar 5, 2008
Sep 20, 2008 9:53 AM in response to: mitchellcipriano
Re: Vfiler and Main Filer System Info
Its same for the Real storage system as well.
22:19[danielpr@siml3 ~] >ontapi 10.72.183.215 root door system-get-info
<system-id>0084189856</system-id>
                <system-model>FAS250</system-model>
                <system-machine-type>FAS250</system-machine-type>
<system-serial-number>3011867</system-serial-number>                <system-revision>C0</system-revision>
                <board-speed>600</board-speed>
                <board-type>TSANTSA</board-type>
                <cpu-part-number>110-00016</cpu-part-number>
                <cpu-revision>E0</cpu-revision>
                <cpu-serial-number>303776</cpu-serial-number>
                <cpu-firmware-release>CFE 1.2.0</cpu-firmware-release>
                <number-of-processors>2</number-of-processors>
                <memory-size>510</memory-size>
                <cpu-processor-type>1250</cpu-processor-type>
        </system-info>
</results>
22:20[danielpr@siml3 ~] >ontapi -v vf1 10.72.183.215 root door system-get-info
        </system-info>
</results>
More Like This
  • Retrieving data ...
Bookmarked By (0)
